Api session event editor netload generate paths
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Generate Paths
0 REQUIRED (NET_FUNCTION Integer ID) Net Function
1 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Load
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/generate_paths/?f=JSON&token=API_TOKEN
with content:
[ 57, [ 1, 2, 3 ], 61, 9 ]
