Api session event editor geoplugin add
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Geo Plugin
0 REQUIRED (Enumeration) Geo LinkType AREA, BUILDING, ROAD, STREET_OBJECT, TERRAIN_HEIGHT or WATER_BOTTOM
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorgeoplugin/add/?f=JSON&token=API_TOKEN
with content:
[ "WATER_BOTTOM" ]
