Api session event editor specialeffect set particle pair location
API Event to Set Particle Pair Location
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Integer number) Integer
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/?f=JSON&token=API_TOKEN
with content:
[ 50, 30, [ 1.0, 2.0, 3.0 ] ]
