Api session event editor specialeffect set particle pair location
API Event to Set Particle Pair Location
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID) | Special Effect | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | double[] |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/?f=HTML&token=API_TOKEN
with content:
[ 69, 96, [ 1.0, 2.0, 3.0 ] ]
