Api session event editor specialeffect set particle pair location
Revision as of 10:24, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Particle Pair Location {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SPECIAL_EFFECT Integer ID) |Special Effects | |- |1 |REQUIRED |(Integer number) |Integer | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |double[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https:/...")
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effects
1 REQUIRED (Integer number) Integer
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/?f=HTML&token=API_TOKEN
with content:
[ 68, 76, [ 1.0, 2.0, 3.0 ] ]
