How to insert a Plotly Graph
This How-to contains the steps on how to create a Template Text Panel, containing a Line chart of a particular Grid Overlay, with calculated Area averages per timeframe using TQL. Plotly will be used to calculate the Line chart in javascript.
Template:Editor steps
  • In case a Template Panel is used, apply the template to generated the panel instances which you can inspect.
  • The generated content for a Text Panel depends on the Template Panel configuration (Maplink, Attribute)
