Heat Reduction (Indicator)
The Heat Reduction indicator computes the effect of urban green on heat reduction. The presence of green reduces heat stress in the surrounding area and therefore cools down the environment. The more urban green space is present in an area, the stronger the heat reduction in that area will be.
This indicator is a simplified version of a RIVM calculation model and was created for a pilot with the RIVM. The indicators in this pilot are co-created with the RIVM, according to their (calculation) methods. They however are not validated as being indicators which calculate according to 'RIVM standards' or something along those lines, since they were for the pilot. More information about this pilot and demo project is available[1].
This indicator is useful for projects where for example:
- reducing heat stress is an important goal in the project
- livability is measured in the project
The Excel indicator can be downloaded from the Public GeoShare. Read on to find out more about the indicator's calculation method and how to set it up in your project.
Indicator panel
The indicator panel shows per neighborhood:
- The name of the neighborhood
- The percentage of urban green space in that neighborhood in the future (planned) situation
- The temperature in that neighborhood in the future (planned) situation
- The average heat reduction in the entire project area
- The target temperature reduction (calculated as 100% GREEN_HEAT_REDUCTION, adjustable as an Indicator attribute)
Calculation
The calculations used in this indicator are based on the RIVM calculations on urban green and health effects[2].
Temperature = AverageTemperature x NeighborhoodArea AverageTemperature = (GreenPercentage x 100) x HEAT_REDUCTION GreenPercentage = GreenArea / TotalArea
Where the variables are:
- Temperature: is the calculated temperature for the entire project area
- AverageTemperature: is the average temperature in the selected neighborhood
- NeighborhoodArea: is the size (m^2) of the selected neighborhood
- GreenPercentage: is the urban green percentage of a neighborhood
- GREEN_HEAT_REDUCTION: is an indicator attribute that indicates the percentage of heat reduction that urban green space has in the selected neighborhood
- GreenArea: is the green effect in the core area
- TotalArea: is the size of the entire area (m^2) specified in the project
- CurrentGreenArea: is the size of the urban green area (m^2) in the neighborhood
- ValidNeighborhood: is a value that indicates if the neighborhood is a valid neighborhood
Score
The score is based on the present urban green spaces in the specified project area. The effect that these urban green spaces have on the heat reduction is visible as the score of the indicator. For each neighborhood the score is based on the average temperature. For the totality of the project area, the average temperatures per neighborhood are weighed by the size of the neighborhood. In other words, the average temperature in a large neighborhood has a greater impact on the final score than that of a smaller neighborhood.
Additional configurations
Add the Indicator Attribute
The Indicator attribute GREEN_HEAT_REDUCTION represents the heat reduction per urban green space fraction in a specified area. It needs to be added to the project manually. The recommended value for this variable is 0.1. This value can be modified according to the needs of the project.
- Select the Heat Reduction Indicator.
- Click on the Attributes Tab
- In the new attribute name field, write GREEN_HEAT_REDUCTION.
- In the new value field, write 0.1.
- Click on the Save New Attribute button to add the attribute to the indicator.
- Update the indicator by clicking on the Calculation Cloud icon in the ribbon bar.
Add the GREEN_HEAT_REDUCTION attribute to the indicator.
- ↑ De economische waarde van natuurlijk kapitaal ∙ Found at: https://www.tygron.com/nl/2018/12/07/de-economische-waarde-van-natuurlijk-kapitaal/
- ↑ Natural Capital Model Technical documentation of the quantification, mapping and monetary valuation of urban ecosystem services ∙ Remme, R. (RIVM), De Nijs, T. (RIVM), & Paulin, M. (RIVM), (2018)
