Terrain Attributes
List of attributes relevant to Terrains and Terrain Types.
Min unsaturated fraction (Terrain Attribute)| Icon | Attribute | Unit | Layer | Range | Description |
| ANGLE_OF_REPOSE | angle (0-90°) | Ground | The different subsurface types each attain a value for the maximum slope (Dutch: talud). This value is used for creating the water edge steepness and indirect for the water depth. | ||
| BOWEN_RATIO | ratio | Surface | 0.001 to 10 | The ratio between two forms of heat transfer between this building's surface and the atmosphere. | |
| BUILDABLE | boolean | Both | 0 or 1 | Whether it is permitted to place Buildings here | |
| COLOR | Color | Both | The color of the terrain. | ||
GROUND_INFILTRATION_MD | m/day | Surface | 0.0 to 10.0 | The speed at which water can flow vertically from the surface to the unsaturated zone. |
GROUND_INFILTRATION_MD | m/day | Ground | 0.0 to 10.0 | The speed at which water can flow vertically from the unsaturated zone to the saturated zone. |
| HEAT_EFFECT | °C | Surface | Measure of impact on the Heat Stress Overlay with the UNESCO-IHE model | ||
HYDRAULIC_CONDUCTIVITY_MD | m/day | Ground | Hydraulic conductivity (K) is a measure of the ease with which water can move through pore spaces or fractures in a saturated medium. | |
HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD | m2/day | Ground | This attribute represents the horizontal hydraulic conductivity (KD) of the saturated layer multiplied by the layer thickness. | |
| LIVABILITY_EFFECT | Surface | Measure of impact on the Livability Overlay. | |||
| PEAT_FRACTION | fraction | Underground | The fraction of the subsurface which will be considered to be peat by the Subsidence Overlay. | ||
ROOT_DEPTH_M | m | Surface | The depth of the roots of the Terrain Type. This depth is used to determine whether evaporation will occur from the groundwater. | |
SUBSIDENCE | boolean | Ground | Whether or not subsidence should be calculated for a terrain or in a given area. Subsidence is calculated when the value is not equal to 0. | |
| TERRAIN_MIX | Surface | ||||
| TEXTURE TYPE | Integer | Surface | 0 to 2 | Value used to select the terrain blend color. | |
| TOPLAYER_THICKNESS | m | Ground | The depth of the clay soil layer, as considered by the Subsidence Overlay. | ||
| VEGETATION_FRACTION | fraction | Surface | The amount of green which this Terrain Type provides per m². | ||
| WATER | nominal | Surface | Whether this Terrain Type represents a form of water (and what type). | ||
| WATER_DEPTH_M | m | Surface | The default depth of this water Terrain Type, relative to the surrounding elevation. | ||
WATER_TRANSPIRATION_FACTOR | factor | Surface | How fast this terrain can evaporate water from the ground. The weather's evaporation speed is multiplied by this factor to determine the rate of transpiration. | |
WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the terrain, which is a measure of surface roughness. Used in the surface flow computation of the Water Overlay. | |
WATER_MICRORELIEF_M | m | Surface | 0 - 0.255 | The defined Microrelief in meters, which captures surface water. When captured, surface flow is halted until the defined threshold is reached. Evaporation and infiltration for water captured in Microrelief is still allowed. |
WATER_STORAGE_PERCENTAGE | fraction (m3/m3) | Ground | The percentage (as a fraction) of the ground layer volume which can be filled with water. A lower percentage means the ground layer will be able to store less water, and the saturated zone will rise higher with the same amount of water in the ground layer. |
