Limit Map
Revision as of 09:21, 17 October 2025 by Frank@tygron.nl (talk | contribs)
This article is a stub. The following information should be added:
  • where is this setting in the UI.
  • what kind of Item is it
  • what happens when set based on a different Item (are changes reflected or not)
  • Affects all grid overlays
  • what about X queries of TQL for items outside limit map
  • Document SKIP_NO_DATA on separate appropriate page.
  • how to page for splitting up calculation
Limit Map is a Setting that stores the Multi Polygon that will be used to limit the calculation of Grid Overlays.
When this setting is configured with a non-empty Multi Polygon, the grid and TQL Queries are limited to a portion of the map. Limit map is always a rectangle bounding box of the Multi Polygon of the setting.
Calculation limited by a Areas, enveloped by a rectangular bounding box
  • When updating Grid Overlays only the box is updated and the rest contains NO_DATA values.
  • Adding SKIP_NO_DATA=1 as an attribute to any Grid Overlay, keeps the orginal values in place. Note: This method allows for calculation larger then the GPU grid would allow by splitting the map up in Limit map boxes.
