Wind decline angle (Heat Overlay)
Revision as of 11:39, 8 November 2024 by Maxim@tygron.com (talk | contribs) (Created page with "{{Overlay attributes| <onlyinclude>{{Overlay attributes|type=row|overlay=Heat |attribute=WIND_DECLINE_ANGLE |unit=Degrees |description=This angle determines how the wind flows down around objects. |defaultvalue=90 |icon= }}</onlyinclude>}} {{article end |notes= * By default the {{Heat DPRA Report}} does not take this effect into account and the value is set to 90 degrees. However a value of e.g. 45 degrees produces more realistic wind flow around objects. {{HeatOverla...")
  • By default the DPRA Heat stress report does not take this effect into account and the value is set to 90 degrees. However a value of e.g. 45 degrees produces more realistic wind flow around objects.
