How to change Function Values for a Function
Revision as of 14:52, 29 February 2024 by Frank@tygron.nl (talk | contribs)
When a Function is added to the list of Functions in the Function Values Table, its name and Function Values can be modified.
How to change Function Values:
  1. If the desired Function is not yet present in the list, add the Function to the list
  2. Find the column with the property you wish to change.
  3. Change the value in the row of the Function and the column of the property.
Editing the construction cost for the function "Roads" using the Function Values Table.
