Terrain Attributes
Water microrelief (Terrain Attribute)
| Icon | Attribute | Unit | Layer | Range | Description |
| ANGLE_OF_REPOSE | angle (0-90°) | Ground | The different subsurface types each attain a value for the maximum slope (Dutch: talud). This value is used for creating the water edge steepness and indirect for the water depth. | ||
| BOWEN_RATIO | ratio | Surface | 0.001 to 10 | The ratio between two forms of heat transfer between this terrain's surface and the atmosphere. | |
| BUILDABLE | boolean | Both | 0 or 1 | Whether it is permitted to place Buildings here | |
GROUND_INFILTRATION_MD | m/day | Surface | 0.0 to 10.0 | The speed at which water can flow vertically from the surface to the unsaturated zone. |
GROUND_INFILTRATION_MD | m/day | Ground | 0.0 to 10.0 | The speed at which water can flow vertically from the unsaturated zone to the saturated zone. |
| HEAT_EFFECT | °C | Surface | Measure of impact on the Heat Stress Overlay with the UNESCO-IHE model | ||
| LIVABILITY_EFFECT | Surface | Measure of impact on the Livability Overlay. | |||
| PEAT_FRACTION | fraction | Underground | The fraction of the subsurface which will be considered to be peat by the Subsidence Overlay. | ||
| TERRAIN_MIX | Surface | ||||
| TEXTURE_TYPE | Integer | Surface | 0 to 2 | Value used to select the terrain blend color. | |
| TOPLAYER_THICKNESS | m | Ground | The thickness of the top layer covering the peat, for the calculation of the compaction component of subsidence, as considered by the Subsidence Overlay. | ||
| VEGETATION_FRACTION | fraction | Surface | The amount of green which this Terrain Type provides per m². | ||
| WATER | nominal | Surface | Whether this Terrain Type represents a form of water (and what type). | ||
| WATER_DEPTH_M | m | Surface | The default depth of this water Terrain Type, relative to the surrounding elevation. | ||
WATER_TRANSPIRATION_FACTOR | factor | Surface | How fast this terrain can evaporate water from the ground. The weather's evaporation speed is multiplied by this factor to determine the rate of transpiration. | |
WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the terrain, which is a measure of surface roughness. Used in the surface flow computation of the Water Overlay. | |
WATER_STORAGE_PERCENTAGE | fraction (m3/m3) | Ground | The percentage (as a fraction) of the ground layer volume which can be filled with water. A lower percentage means the ground layer will be able to store less water, and the saturated zone will rise higher with the same amount of water in the ground layer. |
