ArcGIS Pro
Revision as of 13:30, 13 December 2023 by Frank@tygron.nl (talk | contribs)
Esri ArcGIS Pro[1] is a 64-bit GIS software that is the more modern version of ArcGIS Desktop. Unlike ArcGIS Desktop, the ArcCatalog and ArcMap functionalities are accessed through the same application, most commonly through the Catalog pane.
ArcGIS Pro can directly connect with the Tygron Engine via WFS and WMS.
It can also be used to generate I3S SLPK files for 3D Models that can be imported.
ArcGIS Online
The Tygron Client Application can also obtain data from services located in ArcGIS Online. Private or organizational data can be accessed by first login into the Online or Enterprise portal.
