TQL tutorial
Redirect page
Redirect to:
Prerequisites
- This tutorial can be followed with any project of any arbitrary location, preferable in an urban environment.
Preparations
Introduction to TQL
TQL is an abbreviation for Tygron Query Language. It is a custom query language created to allow for obtaining statistical data from a Project. The language consists of "queries", which can be interpreted as questions asked of the Project. Such a query is composed of a statement, which embodies the requested information, and a number of clauses, which define/filter the data taken into consideration.
TQL queries are an important tool for automated analyses of Projects, both of the Current Situation as well as any Future Designs.
TQL queries by themselves can be used to obtain bits of information. In broader contexts, such as Excel Indicators or Panels, or scripts interacting via the API, the combination of multiple queries allows for obtaining large amounts of information which together can be used for more complex analyses.
Most statements return numerical values which can be used in calculations. Some statements return some form of text.
Query tool
To get started with the creation of queries, open the query tool:
The query tool is an assistive tool for the creation of queries. It helps by offering up options for which clauses can be added to statements and queries. It also allows for executing queries and seeing the results. This means that any created queries can be validated that they function as expected, but also that small bits of information can be requested on-the-fly.
When the query tool opens, a simple query is already composed.
If any clauses are listed, click on "Remove clause" for each of them until no clauses remain. Only the statement should remain.
Ensure the query type is set to "SELECT", which means to request data from the Project.
Ensure the statement is set to "LANDSIDE", which is a request for surface area.
Click on "Execute Query".
The result shown is the surface area found in the Project, unqualified. It will be the size of the Project in its entirety.
Next, click on "Add clause". This adds a qualifier to the query; a filter or rule the data must conform to before being taken into consideration.
Set the clause to "NEIGHBORHOOD", and select a Neighborhood which is well present in the Project.
Then, click on "Execute Query" again.
The result shown is the surface area which lies in the selected Neighborhood.
Note that the composed query is shown in the query tool as well. The dropdowns allow for (and guide) the selection of the individual parts of the query, but the full query is all components strung together.
Also note that using the dropdown, a Neighborhood could be selected by name, but in the actual query the ID of the Neighborhood is used. If the name of the Neighborhood (or any other Item being queried) is ever changed, the ID remains unchanged and thus the query will remain functional.
Basic queries
Statements
To create queries effectively, some knowledge of which statements are available is important. Construct the following queries and see the results:
- SELECT_NAME
- The name of a specific Item.
Create and execute the following query:
SELECT_NAME_WHERE_NEIGHBORHOOD_IS_...
The result is the name of the Neighborhood queried.
- SELECT_LANDSIZE
- The amount of surface area matching whichever qualifiers are provided in the clauses.
SELECT_LANDSIZE_WHERE_
The result is the size of the entire Project area.
- SELECT_LOTSIZE
- The amount of surface area which is taken up by Buildings such as apartments, roads, parks and trees. It's effectively the footprint of all constructions.
SELECT_LOTSIZE_WHERE_
The result is the surface area within the Project area which is taken up by Buildings.
- SELECT_FLOORSIZE
- The footprint of constructions, multiplied by their respective floors. The amount of space which the found constructions contain for use. This includes "single floor" constructions like roads and trees, unless further qualified.
SELECT_FLOORSIZE_WHERE_
The result is the total floorsize of all Buildings in the Project area.
- SELECT_UNITS
- The amount of housing units present. This is calculated by dividing the floorspace of Buildings by their respective UNIT_SIZE Attributes. Buildings which are not representative of housing are ignored.
SELECT_UNITS_WHERE_
The result is the total amount of housing units in the Project area. Note that this may include a fractional housing unit, as it is calculated based on the known/computable floor sizes.
Clauses
- WHERE_NEIGHBORHOOD_IS_...
- The data must be related to, or inside of, this Neighborhood.
SELECT_UNITS_WHERE_NEIGHBORHOOD_IS_...
The result is the total amount of housing units in the specified Neighborhood. Note that this may include a fractional housing unit, as it is calculated based on the known/computable floor sizes.
- WHERE_CATEGORY_IS_...
- The data requested is related to Buildings, and those Buildings must be of a specific Category.
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES
The result is the amount of office space in the Project area.
- WHERE_STAKEHOLDER_IS...
- The data must be related to, or owned by, this Stakeholder.
Create and execute the following query, with the Municipal Stakeholder selected for the STAKEHOLDER clause:
SELECT_LOTSIZE_WHERE_STAKEHOLDER_IS...
The result is the amount of built surface area which is owned by the Municipality.
- WHERE_FUNCTIONMULT_IS_...
- WHERE_CATEGORYMULT_IS_...
- WHERE_ATTRIBUTE_MULT_IS_...
- The data requested is related to Buildings, and the found amount is multiplied by the respective Function Values or Attributes.
SELECT_FLOORSIZE_WHERE_CATEGORYMULT_IS_PARKING_LOTS_DEMAND_PER_M2
The result is the amount of parking spots which are required to meet the parking demand of all Buildings in the Project area. This is calculated by obtaining all the floorsize of all Buildings, and then multiplying it by the respective parking demand for all Buildings.
SELECT_FLOORSIZE_WHERE_CATEGORYMULT_IS_PARKING_LOTS_PER_M2
The result is the amount of parking spots which are available in the Project area. This is calculated by obtaining all the floorsize of all Buildings, and then multiplying it by the respective parking supply for all Buildings.
Assignments
- Create a query to find the amount of social housing in the Project area which is owned by a collective corporation.
- Create a query to find the surface area in a Neighborhood which is taken up by shops and restaurants.
Grid queries
Queries can be used to consult grid data as well. Spatial calculations can produce produce results which allow for a general estimation of outcomes, but of which the exact values may be more difficult to read. For example, a Heat Stress Overlay may compute the location of hot or cool locations, but it may be difficult to compare optically how two different locations compare to one another.
To experiment with queries for grid calculation results, a Grid Overlay should be present in the Project. A Heat Stress Overlay is a good Overlay to experiment with.
Ensure a Heat Stress Overlay is present in the Project
If necessary, ensure the Heat Stress Overlay is recalculated as well.
Grid clauses
Construct the following queries and see the results.
- WHERE_GRID_IS_...
- The grid to use. Whenever a query is constructed to consult data related to a query, the consulted grid must be specified as well.
- WHERE_TIMEFRAME_IS_...
- The Timeframe of the grid to use. When absent, the last Timeframe of the Grid Overlay is used.
- WHERE_MINGRIDVALUE_IS_...
- Consulting only grid cells the value of which is at least the specified value. (Inclusive, so a cell with the exact value is included.)
- WHERE_MAXGRIDVALUE_IS_...
- Consulting only grid cells the value of which is at most the specified value. (Exclusive, so a cell with the exact value is excluded.)
Create and execute the following query, with the Heat Stress Overlay selected for the GRID clause:
SELECT_LANDSIZE_WHERE_MINGRIDVALUE_IS_35.0_AND_MAXGRIDVALUE_IS_45.0_AND_GRID_IS_...
The result is the surface area in the Project area which has calculated temperatures in the range of 35°C to 45°C.
Grid statements
- SELECT_GRIDAVG
- The average value of grid values.
SELECT_GRIDAVG_WHERE_GRID_IS_...
The result is the average temperature in the Project area.
Assignments
- Create a query to obtain the average temperature in a specific neighborhood.
- Create a query to obtain the surface area of roads in a specific neighborhood with a temperature of at most 40 degrees.
Combined queries
Queries are composed of a single statement, and a number of clauses. The clauses are always connected with an "AND" operation. This means that the data obtained by the query must match all the clauses.
Although TQL does not have an "OR" operation, its functionality can be easily replicated simply by performing complementary statements.
A practical example is obtaining the amount of floorspace of all types of housing combined. There are multiple categories of housing: SOCIAL, NORMAL, LUXE, SENIOR, STUDENT. By using 5 queries, one for each category, the total amount of floorspace of housing can be obtained.
This principle extends beyond cumulative or complementary data. Other mathematical operations are possible as well.
A practical example is that the amount of actual land can be obtained using the following queries, and subtracting the results from one another:
SELECT_LANDSIZE_WHERE_ SELECT_LANDSIZE_WHERE_TERRAIN_WITH_ATTRIBUTE_IS_WATER
By subtracting all surface area which is a Water Terrain from the total surface area, what remains is all the surface area which is not water.
Final assignments
These assignments require multiple queries. Perform the required queries in sequence, note the results, and manually perform any calculations using the results to obtain the answer.
- Using a LANDSIZE query and a LOTSIZE query, compute the amount of surface area which does not contain a Building in a specific Neighborhood.
- Compute the percentage of a specific Neighborhood in use for housing.
- Using a UNITS query and a FLOORSIZE query, compute the average size of houses in a specific Neighborhood.
- Continuing from that, compare the average size of social housing in a specific Neighborhood with the average size of luxury housing in that same Neighborhood.
Tutorial completed
Congratulations. You have now completed this tutorial. In it, you have learned how to create Combo Overlays, and how to create TQL queries, and the most commonly used query components.
