How to add a GeoTIFF to a measure
Revision as of 09:04, 6 November 2023 by Bobby@tygron.nl (talk | contribs)
Adding a geotiff to a measure can be very useful if you want to evaluate different scenario’s of your height map. For example, to evaluate the impact of a wadi on water stress, or the impact of a sound wall on noise pollution.
How to add a GeoTIFF to a measure:
Watch the video:
  1. Add a measure and select it.
  2. In the lower left of the interface, click on the button Add Tiff Spatial.
  3. Move to the Tiff Spatial detail panel in the right of the interface and click the Add Tiff button.
  4. The GeoTIFF selection panel now opens.
  5. If you want to import new GeoTIFFs from your computer or from the GeoShare, you can now do so.
  6. Once done importing, select one or more GeoTIFFs and confirm.
  7. The selected GeoTIFFs should now show up in the Tiff Spatial detail panel.
  8. Notice the checkbox below named "Calculate Area from Tiffs automatically".
  9. If you want to manually restrict the area where this Tiff Spatial is applied to, uncheck this option. Next,click on the button below the checkbox to manually draw an area for the Tiff Spatial. The Tiff Spatial 's GeoTIFFs will only be applied for that area when activating this measure.
  10. Otherwise, the MultiPolygon for the Tiff Spatial is automatically calculated by the Tygron Platform once the GeoTIFF changes are send to the server. This calculation might take a while depending on the amount and complexity of GeoTIFFs supplied.
  • You can add more than one GeoTIFF to a TiffSpatial of a measure.
  • Multiple GeoTIFFs can be selected by using shift and ctrl in the GeoTIFF selection panel.
  • You can manually provide the MultiPolygon for which the GeoTIFFs are applied.
  • You can practise this using the DXF demo project
