GeoShare Viewer
Revision as of 13:50, 1 November 2023 by Maxim@tygron.com (talk | contribs)
Example of a GeoShare Viewer showing a Water Overlay with multiple timeframes and the option on the left to show two other feature layers.
A GeoShare Viewer is a functional viewing application hosted on and served by the GeoShare. They can be used to share insight into geographical data GeoJSONs and GeoTIFFs in a user-friendly way, with their primary intended use being the sharing of results from calculations such as flood analyses or heat stress effects.
Like other Geo Data on the GeoShare, it is accessible through a url outside of running Sessions, regardless of the contents of the data. This will open a web-based interface in which the data of the viewer can be inspected or played, if the data consists of multiple timeframes. The extent of the viewer is based on the extent of the data which is part of it. The viewer can be configured to require a token for authentication.
GeoShare Viewers do not take up a significant amount of space on the GeoShare. However, the data a GeoShare Viewer relies on must continue to exist on the GeoShare.
