How to compute residential walls with sight of trees
Revision as of 12:39, 25 August 2023 by Rudolf@tygron.nl (talk | contribs) (Created page with "For the 3-30-300 guidelines, the rule indicated by the "3" is the ability to see 3 trees out of residential windows. This can be computed in the {{software}} by calculating the locations of residential walls, and the sightlines onto trees. {{editor location|Overlays}} {{editor location|title=compute residential walls with sight of trees | Add an Attribute to the Function of Default Decidious Trees, nam...")
For the 3-30-300 guidelines, the rule indicated by the "3" is the ability to see 3 trees out of residential windows. This can be computed in the Tygron Platform by calculating the locations of residential walls, and the sightlines onto trees.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar)
  • The resulting Combo Overlay has values of 0 where there are walls without sight of a tree, and values of 1 where there are walls with sight of a tree.
  • Although the different steps in the calculation may produce coarse results, over a large scale the imperfections can balance out and the calculation as a whole can provide relevant insights into the compliance to the guideline.
  • At this time this calculation can only determine sightlines to a tree, not neccesarily to the prescribed 3 or more trees. However, in most urban environments trees exist in groups which can alleviate the discrepancy somewhat.
