How to add spatial elements to measure from a DXF file
Revision as of 11:51, 10 May 2023 by Bobby@tygron.nl (talk | contribs)
Measures are a powerful means of setting up a future situation. Because they can encompass a large amount of individual features, importing them from pre-made Geo Data files will save a lot of time. However, such plans can sometimes contain a water component, which will require a bit more attention to import properly.
How to import a measure with water features:
- Open the geo import wizard.
- Opt to import a measure via a DXF file. See How to import a DXF as a measure.
- Select the desired datatype and precise datasource, and continue through the wizard.
- Finalize and close the wizard. A Measure is now added to the Project.
- Go to Future Design, and then Measures, to open the list of Measures. A new Measure named "Measure" will be available.
- Select the newly created Measure, and change the name to an appropriate name for the plan.
- Click on "Add Spatial" to add a Spatial element to the Measure.
- Select the Spatial, and opt to draw the outer area of the Spatial.
- Use the "Blueprint" drawing option, and then opt to use the wizard to set a selection. This will reopen the geo import wizard.
- Select "an AutoCAD DXF file". Choose file locally or from the GeoShare.
- Choose layer that the outer water contour has been drawn in
- Continue through the wizard and finish it. The water features from the plan will be added as a pending selection to the current drawing action for the Water Spatial.
- Click on "Apply selection" to confirm the outer edge of the Water Spatial.
- Opt to draw the inner area of the spatial.
- Use the "Blueprint" drawing option again and repeat process but this time choose the inner water layer.
- Set the relative height change of the spatial to a sensible water depth.
- The Measure now consists of both the imported Buildings and the water feature(s).
- Due to the generally large number of features, it is advised to use a Geo Plugin to match functions to features in the Assign Function step of the Geo Data Wizard. This is especially useful when the DXF's layers and blocks use standardized names and attributes, such that you can reuse the GeoPlugin in multiple projects.
