How to set linear evaporation rate (Water Overlay)
Revision as of 15:14, 23 February 2023 by Frank@tygron.nl (talk | contribs)
For a Water Overlay, evaporation rate is defined in Weather data.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → Configuration Wizard (Right panel)
How to set linear evaporation rate:
- Open the configuration wizard of the Water Overlay.
- Continue to the step concerning weathers.
- Select the weather event you wish to update, or select "Add" to create a new one.
- Set the "Surface evaporation" setting to "Linear".
- In the "Surface evaporation" field, set the desired evaporation rate.
- Close the wizard.
The evaporation rate is in mm/day, so for any given evaporation rate configured, the total amount of evaporation will be less as simulation time decreases.
