Tracer ABCD (Water Overlay)
Revision as of 10:54, 4 December 2020 by Frank@tygron.nl (talk | contribs) (Frank@tygron.nl moved page Substance ABCD (Water Overlay) to Tracer ABCD (Water Overlay) without leaving a redirect)
Template:Construction attributes
Constructions with a positive SUBSTANCE Attribute are known as chemical emitters. Constructions with a negatice SUBSTANCE Attribute are known as chemical decomposers.
Structures which are defined to create a negative amount of chemicals function as a scrubber or decomposer, removing the specified quantity of chemicals from the hydrological model.
In situations where water is absent, chemicals will not be moved between cells.
  • Chemical emitters must be constructions on the surface, not underground constructions.
  • Chemical emitters's attributes do not take the form of function values, and thus must be added manually or as part of loading in geodata.
  • Chemicals have generic definitions, in terms of name and magnitude, to allow for the modeling of arbitrary substances.
Template:WaterOverlay hydrological construction attribute nav
