How to add an Answer to a Panel
Revision as of 13:09, 31 July 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "Panels can be assigned Answers, which allow an end-user to interact with a Session based on the information provided in the Panel. {{editor location|Panels}}...")
Editor → Current Situation (Ribbon tab) → Panels (Ribbon bar)
How to add an Answer to a Panel:
  1. Open the list of Panels.
  2. Select the Panel you wish to add an Answer to.
  3. Click on "Add Answer".
  4. The Panel now has an answer.
  • If the Panel is not set to be visible in its current state or to the current Stakeholder, you can still check whether the Panel has a location set by moving the camera and then selecting the Panel in the left panel. If the camera automatically moves to the intended location in the 3D world, the location of the Panel has been set successfully.
