Ground bottom flow formula (Water Overlay)
Underground seepage (from (or to) outside the project area) is calculated per cell.
The seepage is calculated using the following formula:
Δs=hd(t)−hx,yc⋅Δt24⋅60⋅60
The external seepage head is variable over time by the introduction of hv,t
hd(t)=hc+hv,t(t)
Finally, calculate the actual amount of water infiltrating.
Δw=Δsws
Where:
  • Δs = The underground seepage which takes place, in meters.
  • Δt = Computational timestep in seconds.
  • hd = ground water level (or head) of the external zone causing the seepage, in meters
  • hv> = additional variation in head of hd over time
  • c = resistance of the separating layer in days
  • ws = soil water storage fraction
Groundwater level formula
Surface infiltration formula
Models
Underground model
Infiltration model
Substance flow model
Template:WaterOverlay nav
