Ground bottom flow formula (Water Overlay)
Underground seepage (from (or to) outside the project area) is calculated per cell.
The seepage is calculated using the following formula: δs
Failed to parse (syntax error): {\displaystyle \delta s = frac{(h_{d}(t) - h_{x,y}}{c} \cdot frac{Δt}{24*60*60}}
The external seepage head is variable over time by the introduction of hv,t
hd(t) = hc + hv,t(t)
Finally, calculate the actual amount of water infiltrating.
Δw = Δs/ ws
Where:
  • Δs = The underground seepage which takes place, in meters.
  • Δt = Computational timestep in seconds.
  • hd = ground water level (or head) of the external zone causing the seepage, in meters
  • hv> = additional variation in head of hd over time
  • c = resistance of the separating layer.
  • ws = soil water storage fraction
Groundwater level formula
Surface infiltration formula
Models
Underground model
Infiltration model
Substance flow model
Template:WaterOverlay nav
