How to remove a Panel
Revision as of 09:29, 1 July 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "Panels can be removed from a Project. {{editor location|Panel}} {{howto|title=remove a Template Panel | Open the list of Panels. | Open the "Single Panels" listi...")
Editor → Current Situation (Ribbon tab) → Panels (Ribbon bar) → The Panel to edit (Left panel)
How to remove a Template Panel:
  1. Open the list of Panels.
  2. Open the "Single Panels" listing.
  3. In the left panel, select the panel to remove.
  4. At the bottom of the left panel, select "Remove".
  5. The Panel is now removed from the Project.
  • To remove instances of a Template Panel, comparable steps can be taken. However, in those cases it is recommended to reconfigure the [[Template Panel]'s filter so that the superfluous instances are not created when the Template Panel is reapplied.
