How to configure a Template Panel
Revision as of 11:34, 30 June 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "Template Panels allow similar Panels to be easily and automatically created. Template Panels must be configured before they result in the desired elements. {{edito...")
Editor → Current Situation (Ribbon tab) → Panels (Ribbon bar) → Template panels (Left panel) → The Panel to edit (Sub-option)
How to add a Template Panel:
  1. Open the list of Panels.
  2. In the left panel, select Template Panels.
  3. In the right panel, set the desired name for the resulting Panels. Note that this will be combined with the target Item's name.
  4. If the Panel should only be visisble to a specific Stakeholder, in the right panel, set the Stakeholder whom should be able to see the Panel.
  5. In the right panel, set the content which should be displayed by the Panels.
  6. At the bottom of the right panel, select the type of Item the Template Panel should be used on.
  7. At the bottom of the right panel, click on "Apply Template", and confirm the prompt.
  8. The instances of the Template Panel are now created.
