Tracer ABCD (Water Overlay)
Revision as of 12:22, 15 June 2020 by Rudolf@tygron.nl (talk | contribs)
| SUBSTANCE_A | x/m²/s | The amount of substance A created per second per m² in this location. | 0 |
| SUBSTANCE_B | x/m²/s | The amount of substance B created per second per m² in this location. | 0 |
| SUBSTANCE_C | x/m²/s | The amount of substance C created per second per m² in this location. | 0 |
| SUBSTANCE_D | x/m²/s | The amount of substance D created per second per m² in this location. | 0 |
Chemical emitters/decomposers
Structures which are defined to create a negative amount of chemicals function as a scrubber or decomposer, removing the specified quantity of chemicals from the hydrological model.
In situations where water is absent, chemicals will not be moved between cells.
- Chemical emitters must be constructions on the surface, not underground constructions.
- Chemical emitters's attributes do not take the form of function values, and thus must be added manually or as part of loading in geodata.
- Chemicals have generic definitions, in terms of name and magnitude, to allow for the modeling of arbitrary substances.
- Surface flow formula
- Underground flow formula
- Surface infiltration formula
- Underground infiltration formula
- Surface model
- Underground model
- Infiltration model
- Substance flow model
Template:WaterOverlay hydrological construction attribute nav
