Function values are specific values which form the general properties of any construction with a specific function. A function has many function values, and any construction of that function also has those function values.
Function values can be changed for an individual construction, or for a function, which in turn would affect all constructions of that function.
Category values
Some function values are construction-related, and some function values are category-related. The difference between them is only applicable if a single function consists of multiple function categories. For example, the function value indicating the maximum amount of floors for the construction is related to the construction as a whole. However, if the function contains both social housing and luxury housing, the individual types of housing can have different unit sizes configured, as one type of housing may offer bigger housing units than the other.
Overview of all function values
Name
| Function value
Attribute
Unit
Per category
Description
| Name
(Property of function value)
text
The name of the Function.
Assets and visualisation
| Function value
Attribute
Unit
Per category
Description
| Image
Image (png, 200x100)
The image used to represent this function. This property is currently unused.
| Roof Color
ROOF_COLOR
color
The color of the roof of a construction. For flat constructions (such as gardens and roads), it is also the color of the ground surface.
| Ground Color
GROUND_COLOR
color
The color of the walls of the bottom floor of a construction.
| Extra Color
EXTRA_COLOR
color
The color of the walls of the floors of the construction which are neither the top nor bottom floor.
| Top Color
TOP_COLOR
color
The color of the walls of the top floor of a construction, unless that floor is also the bottom floor.
| Description
text
The textual description of this function, which is displayed to the user when using this function as as action.
Construction
| Function value
Attribute
Unit
Per category
Description
| Category weight
CATEGORY_WEIGHT
weight
Yes
How much of a construction of this function is classified under the specified category.
| Construction time in months
CONSTRUCTION_TIME_IN_MONTHS
months
How long it takes to construct a construction of this function during a timeline session.
| Default floors
DEFAULT_FLOORS
integer
How many floors a construction of this function will have by default, unless otherwise specified. When using this Function as an Action, this is the default amount of floors created, unless the user changes this setting while performing the Action. This values must always be in the range of min floors and max floors (inclusive).
| Demolish time in months
DEMOLISH_TIME_IN_MONTHS
months
How long it takes to demolish a construction of this functon during a timeline session.
| Floating
FLOATING
boolean
Whether this construction should be visualized with a "floating" animation, as if on water.
| Floor height m
FLOOR_HEIGHT_M
m
The height of each floor of the construction.
| Max floors
MAX_FLOORS
integer
The maximum amount of floors this construction (or any of its sections) can have. This also limits how many floors a construction can have when used as an action during a session.
| Min floors
MIN_FLOORS
integer
The minimum amount of floors this construction (or any of its sections) should have. This also limits how many floors a construction must have when used as an action during a session.
| Monumental
MONUMENTAL
boolean
Whether this construction is monumental. Projects can be set up so that monumental constructions enjoy special protections or have additional qualitative value.
| Slanting roof height
SLANTING_ROOF_HEIGHT
m
How high the slanting roof at the top of the construction should be visualized at its peak. The roof will slant inwards equally from all sides.
| Unit size
UNIT_SIZE_M2
m²/unit
Yes
How large a single housing unit within this construction is. This is only relevant for residential categories.
| Zoning permit required
ZONING_PERMIT_REQUIRED
boolean
Whether the municipal stakeholder should be requested permission, when another user uses this function as an action to plan a new construction during a session
Environment
| Function value
Attribute
Unit
Per category
Description
| Critical infrastructure
CRITICAL_INFRASTRUCTURE
boolean
Whether this construction counts as critical for Water Overlay calculations. See also: Critical structure (Water Overlay)
| Distance zone
DISTANCE_ZONE_M
m
The distance drawn in the Distance Zone Overlay by this construction.
| Disturbance distance
DISTURBANCE_DISTANCE_M
m
The distance drawn in the Disturbance Distance Overlay by this construction.
| Green space
GREEN_M2
m²/m²
The amount of green which this construction provides per m² created. Generally, this number is used along with the constructon's footprint, rather than its total floor size.
| Heat effect
HEAT_EFFECT
decimal
The effect this construction has on the Heat Overlay calculations.
| Livability effect
LIVABILITY_EFFECT
decimal
The effect this construction has on the Livability Overlay calculations.
| Safety distance
SAFETY_DISTANCE_M
m
The distance drawn in the Safety Distance Overlay by this construction.
Financial
| Function value
Attribute
Unit
Per category
Description
| Buyout cost
BUYOUT_COST_M2
currency/m²
Yes
How much it costs, in addition to the demolition costs, to demolish this construction during a session, when the construction is not vacant. These costs are due to eviction or buyout of existing tenants.
| Construction cost
CONSTRUCTION_COST_M2
currency/m²
Yes
How much it costs to create a new construction, when using this function as an action during a session.
| Demolition cost
DEMOLISH_COST_M2
currency/m²
Yes
How much it costs to demolish this construction during a session. If the construction is not vacant, the buyout costs are applicable as well, in addition to the demolition costs.
| Sell price
SELL_PRICE_M2
currency/m²
Yes
How much revenue is generated for the owner, when a construction of this function is created during a session. The income is only generated once.
Network
| Function value
Attribute
Unit
Per category
Description
| Heat flow change per year
HEAT_FLOW_M2_CHANGE_PER_YEAR
m²/year
Yes
For any net load connected to an address part of a construction of this function, the amount of resources (FLOW) requested in addition to those in the starting year during every subsequent year. The amount of resources requested starts at HEAT_FLOW_M2_START_VALUE in the start year, and is then increased by this value every year until the building's year of construction, and finally multiplied by the size of the address(es) the net load is associated with to get a default FLOW value for the net load.
| Heat flow formula start year
HEAT_FLOW_M2_START_YEAR
year
Yes
For any net load connected to an address part of a construction of this function, the start year for the calculation of the amount of resources (FLOW) requested. The amount of resources requests starts at HEAT_FLOW_M2_START_VALUE in this year, and is then increased by HEAT_FLOW_M2_CHANGE_PER_YEAR every year until the building's year of construction, and finally multiplied by the size of the address(es) the net load is associated with to get a default FLOW value for the net load.
| Heat flow to power multiplier
HEAT_POWER_TO_FLOW_MULTIPLIER
factor
Yes
For any net load connected to an address part of a construction of this function, the divisor used to convert the automatically calculated FLOW to an automatically calculated POWER attribute. The automatically calculated FLOW divided by this value is the automatically calculated POWER. Note that an explicitly defined FLOW attribute is not used in this calculation.
| Heat flow value at start year
m²
Yes
For any net load connected to an address part of a construction of this function, the amount of resources (FLOW) requested by the net load in the defined starting year. This value is increased with the HEAT_FLOW_M2_CHANGE_PER_YEAR, until the building's year of construction, and finally multiplied by the size of the address(es) the net load is associated with to get a default FLOW value for the net load.
| Pipes permitted
PIPES_PERMITTED
boolean
Whether net lines are allowed to be generated under this construction.
Traffic
| Function value
Attribute
Unit
Per category
Description
| Height offset
HEIGHT_OFFSET_M
m
How many meters above or below the calculated ground this construction should be visualized. This is intended for bridges, so that they can be lined up appropriately with the surrounding land.
| Lanes
TRAFFIC_LANES
integer
How many lanes of traffic there are on this road. A negative value causes vehicles to move in the opposite direction. This is only relevant for roads, intersections, and bridges. This affects the visualisation.
| Noise sigma
TRAFFIC_NOISE_SIGMA
dB(A)
Difference in noise intensity of vehicles at their reference speed. Effectively a flat modifier in noise.
| Noise tau
TRAFFIC_NOISE_TAU
dB(A)
Difference in noise intensity of vehicles for every order of magnitude difference with their reference speed. Effectively a speed-dependent modifier in noise.
| Parking lots
PARKING_LOTS_PER_M2
parking lot/m²
Yes
How many parking lots are available per m² of this construction.
| Parking lots demand
PARKING_LOTS_DEMAND_PER_M2
parking lot/m²
Yes
How many parking lots are required per m² of this construction.
| Speedlimit
TRAFFIC_SPEED
km/h
How fast vehicles move on this construction. This is only relevant for roads, intersections, and bridges. This affects the visualisation, and the calculations for the Traffic Noise Overlay and the Traffic NO2 Overlay
| Units per hour
TRAFFIC_FLOW
vehicles/h
How many vehicles move over any given cross-section of the road per hour, spread across all lanes. This is only relevant for roads, intersections, and bridges. This affects the visualisation, and the calculations for the Traffic Noise Overlay and the Traffic NO2 Overlay
Water
| Function value
Attribute
Unit
Per category
Description
Model-specific articles
| Connected top sewer area
SEWERED
boolean
Whether this construction can be connected to a sewer.
Sewered (Water Overlay)
| Depth of plant roots
ROOT_DEPTH_M
m
The depth of the roots of the plants of this construction.
Root depth m (Water Overlay)
| Drainage
DRAINAGE
m
Whether this construction has drainage, which affects the calculation of the Subsidence Overlay. A negative value means passive drainage. A positive value means active drainage.
| Ground infiltration per day
GROUND_INFILTRATION_MD
m/day
The permeability of this construction to water trying to infiltrate into the ground.
Ground infiltration md (Water Overlay)
| Manning value
WATER_MANNING
s/(m1/3)
The manning value of the construction, which is a roughness in regards to water flow.
Water manning (Water Overlay)
| Water evaporation
WATER_EVAPORATION_FACTOR
factor
How much this construction facilitates water evaporating from the underground.
Water evaporation factor (Water Overlay)
| Water storage
WATER_STORAGE_M2
m³/m²
How much water can be stored in this construction. This affects the calculation of the Water Storage Indicator and calculation of the Water Overlay.
Water storage (Water Overlay)
Besides the function values which are provided by default, it is possible to add user-defined attributes to function values as well. Any attribute added is automatically available as an attribute for all functions, and all constructions, although the default value of the attribute will be 0.
User-defined attributes added to a function value always apply to the construction as a whole, and cannot be category-specific.
| Function value
Attribute
Unit
Per category
Description
| (user defined)
(user defined)
(user defined)
Attributes can be used to assign any additional values or properties to functions and the constructions which derive from them.
