Sewer Overflow formula (Water Overlay)
The sewer base height is located at the height indicated by the sewer overflow:
Bs = Bo + Ba
The water level at the sewer is then:
ws = hs + Bs
The sewer overflow threshold height Ho within the sewer is calculated as:
Ho = Hs * To
Water only flows out of the sewer if:
hs > Ho and
hs + Bs > wo
The amount that can overflow relies on both the water level at the sewer overflow itself as well as the sewer overflow threshold and the stored sewer water:
Δh = min ( hs - Ho , ws - wo)
The flow is then calculated with the SEWER_OVERFLOW_SPEED attribute of the sewer overflow and the maximum speed with which water can flow through the sewer overflow:
Δw = min( Δh, Δt * qo / As)
The amount of water added to the exit cell(s) of the sewer overflow:
Qt = Δw * As
  • hs = The sewer water height.
  • Hs = The SEWER_STORAGE attribute of the sewer area, the maximum water height allowed in the sewer.
  • Δh = The amount of water that can flow out of sewer based on the threshold and the water levels inside and outside the sewer.
  • Δw = Water level change in the sewer, due to sewer overflow taking place.
  • As = The surface area of the sewer.
  • The sewer's surface area is computed as the amount of sewered grid cells times the size of a grid cell.
  • The sewer's height relative to datum is not defined in the sewer itself. It is relative to the sewer overflow and determined by the SEWER_OVERFLOW attribute of the overflow.
Structures and features
Sewer area
Sewer overflow
Models
Surface model
Sewer model
Template:WaterOverlay nav
