Sewer model (Water Overlay)
Revision as of 09:30, 12 April 2019 by Frank@tygron.nl (talk | contribs)
Sewers can be implicitly activated and deactivated by adding or removing Sewer areas. If no sewer areas exist, no sewers are available in the water model and no water can flow to and from there.
File:Sewer model.png
Sewer Overflow
Rain water can flow from a sewer overflow back onto the surface via a Sewer overflow. A sewer overflow removes water from the sewer and places it on the surface of the cell where the overflow is located. The speed at which this water flows is determined by the SEWER_OVERFLOW_SPEED.
File:Sewer overflow model.png File:Sewer overflow model2.png
External area
Water can also be removed from a sewer to an region outside the project area. This is controlled through the sewer area's SEWER_PUMP_SPEED. The water removed this way is removed from the hydrological model and cannot return back into the project area.
Template:WaterOverlay nav
