Surface model (Water Overlay)
Revision as of 12:11, 11 April 2019 by Frank@tygron.nl (talk | contribs)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface. In order to simulate flowing water, the project area is discretized into x by y cells, based on the configured grid cell size.
Secondly a model is required which describes the rules that need to be followed. For this we use the two-dimensional Saint-Venant system, which reads:
File:2D-Saint-Venant system.png
In the Tygron Platform this model is implemented using the Well Balanced Positivity Preserving Central-Upwind Scheme described in Kurganov and Petrova (2007)[1]. For more information about the model's implementation, see Surface flow formula.
The implemented method rewrites the h from the original Saint-Venant system to w = h + z. See the following image for clarification on the terms water level, surface (or bottom) elevation and water height:
B = surface elevation of grid cell;h = water height of grid cell;w = water level of grid cell.
Surface water level initialization
  1. Kurganov A, Petrova G (2007) ∙ A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ found at: http://www.math.tamu.edu/~gpetrova/KPSV.pdf (last visited 2018-06-29)
Template:WaterOverlay nav
