Water Overlay
What are the Water Overlays
Configuration
Configuration wizard
File:Config wizard.JPG
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Manual configuration
Data
Model connections
Terrain height
Main article: Terrain height
Template:GeoTIFFSpec
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Evaporation
Ground water
Subsidence
Hydrological features
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposers
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
Result child overlays
Calculations
Models
Surface model
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Storage model
Chemical flow model
Model border
Timestep formula
Δt = Δx /umax
Where:
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
Where:
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
WHunderground = Wsat / WSP
Where:
Surface infiltration formula
Infiltration capacities:
Cwater = Wsurface
Ctop = max( Icon, Isurf )
Actual infiltration:
Δw = min( Cwater , Δt * Ctop)
Where:
S = Wunsat/Hunsat
Δw = Cinf * S
Where:
Underground flow formula
Culvert formula
Weir formula
Pump formula
Δw = min( Wlower , Δt * PS )
Where:
Overflow formula
Overflow can take place when:
Hsewer + SO - Hoverflow > 0
Actual overflow:
Inlet formula
If a Tlower is defined:
If a IQ is defined:
Cspeed = Δt * IQ
If a Ctotal is defined:
Cincap = Cused - Ctotal
Δw = max( 0 , Cinthres , Cspeed , Cincap ) / cell
If a IQ is defined:
Cspeed = Δt * IQ
Coutcap = -Ctotal - Cused
Δw = min( 0 , Coutthres , Cspeed , Coutcap ) / cell
Where:
  • cell = Cell size.
Surface evaporation formula
Evaporation capacities:
Δw = Δwunsat + Δwsat
Where:
Calculation time impact
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Attributes tab
  1. ↑ 1.0 1.1 Kurganov A, Petrova G (2007) ∙ A Second-Order Well-Balanced Positivy Preserving Central-Upwind Scheme for the Saint-Venant System ∙ p 15 ∙ found at: http://www.math.tamu.edu/~gpetrova/KPSV.pdf (last visited 2018-06-29)
  2. ↑ 2.0 2.1 2.2 Zsolt Horváth, Jürgen Waser, Rui A. P. Perdigão, Artem Konev and Günter Blöschl (2014) ∙ A two-dimensional numerical scheme of dry/wet fronts for the Saint-Venant system of shallow water equations ∙ found at: http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.700.7977&rep=rep1&type=pdf ∙ http://visdom.at/media/pdf/publications/Poster.pdf ∙ (last visited 2018-06-29)
  3. ↑ Rezzolla L (2011) ∙ Numerical Methods for the Solution of Partial Differential Equations ∙ found at: http://www.scirp.org/(S(lz5mqp453edsnp55rrgjct55))/reference/ReferencesPapers.aspx?ReferenceID=1886006 (last visited 2018-06-29)
  4. ↑ Kurganov A, Petrova G (2007) ∙ A Second-Order Well-Balanced Positivy Preserving Central-Upwind Scheme for the Saint-Venant System ∙ found at: http://www.math.tamu.edu/~gpetrova/KPSV.pdf (last visited 2018-06-29)
  5. ↑ Bollermann A, Chen G, Kurganov A and Noelle S (2014) ∙ A Well-Balanced Reconstruction For Wetting/Drying Fronts ∙ found at: https://www.researchgate.net/publication/269417532_A_Well-balanced_Reconstruction_for_Wetting_Drying_Fronts (last visited 2018-06-29)
