Water Overlay
What are the Water Overlays
Configuration wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Model connections
Terrain height
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Rain should never be negative
First entry Second entry
Time (s) Rain (m)
Evaporation
Evaporation CSV specification
Time (s) Evaporation (m)
Ground water GeoTIFF
Template:GeoTIFFSpec
Subsidence
Hydrological features
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposers
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
Result child overlays
Calculations
Models
Surface model
Water can also be added to or removed from the water model by line-based hydrological constructions. Based on the construction's underlying formula water can be added or removed to the cell indicated by the construction. Only that single cell will receive or lose the calculated amount of water.
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Storage model
Chemical flow model
Model border
Timestep formula
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
Surface infiltration formula
Surface infiltration capacity is calculated per cell.
I = min(Icon, Isurf)
  • I = The cell's infiltration capacity (m/day)
Δw = (Δt * Iund * Wunsat) / (GBDM - (Wsat/WSP))
  • Wsat = The amount of water stored in the saturated zone.
  • Wunsat = The amount of water stored in the saturated zone.
Underground flow formula
Culvert formula
Weir formula
Pump formula
Overflow formula
Whether overflow can take place:
Coverflow = Hsewer + SO - Hoverflow
Actual overflow:
Δw = min( Wsewer, Δt * SOS )
Δw = The amount of sewer overflow which takes place. Δt = Computational timestep.
  • Coverflow = The amount of water which can overflow from the sewer.
  • Wsewer = The amount of water in the sewer.
  • Hsewer = The average height of the terrain where the sewer is present.
  • Hoverflow = The height of the terrain at the centerpoint of the sewer overflow.
Inlet formula
Surface evaporation formula
Δw = min( W , Δt * Eweather * Eoverlay )
Evaporation capacities:
Csat = max( 0 , (Wsat/WSP) - (GBDM/Rtop) )
Csat is 0 if Rtop = 0
Cunsat = min( Wunsat , (Rtop*Wsat/(GBDM - (Wsat/WSP))) )
Cunsat = 0 if Rtop = 0
Cunsat = 0 if GBDM - (Wsat/WSP) = 0
Actual evaporation:
Δwunsat = min( Δt * Eweather * Etop , Cunsat )
Δwsat = min( (Δt * Eweather * Etop) - Δwunsat , Csat )
  • Δwsat = The actual evaporation which takes place from the saturated zone.
  • Δwunsat = The actual evaporation which takes place from the unsaturated zone.
  • Cunsat = The amount of evaporation that can take place from the saturated zone.
  • Wsat = The amount of water in the saturated zone.
  • Wunsat = The amount of water in the saturated zone.
  • Rtop = The ROOT_DEPTH_M of the construction if present, the ROOT_DEPTH_M of the surface terrain otherwise.
Calculation time impact
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Attributes tab
