Project Sources
What are Project Sources
Project Sources are the Geo data sets that are used to create the 3D model in the Engine with. Also, all the additional data a user has imported is listed in the Project Sources.
Where to find the Project Sources
These Project Sources are visible in different overviews in the editor:
- In the hover panel when clicking in the 3D world in the default view
- In the Source Overlay
- In the Project Source Table (see below for more information)
- In the Project Sources (see below for more information)
How to show the Project Sources Table:
- Select in the editor 'Geo Data' from the ribbon
- Hover over 'Geo Import' from the ribbon bar
- Select 'Show Project Sources Overview'
The Project Source Table shows in a table view:
- the name of the dataset
- the type
- the publisher of the dataset
- the number of features in the 3D model (count).
- If the count is 0, this either means the data is not used for generating the 3D model or the data is a raster dataset which technically does not contain features, but cells with a value. The cells are not counted in this table.
Project Sources
How to show the Project Sources edit menu:
- Select 'Show Project Sources'
The Project Sources menu shows the used geo data sets in the 3D model and the by a user imported data. However, in this menu, detailed information about what is in the datasets and the possibility to rename/remove a WFS or CSW connection can be done here.
The sources are divided in three categories:
- Catalog Services
- Here are the by default available CSW connections in the Geo Data Wizard visible. Also CSW connections added by a user are listed here.
- When a user added a CSW connection, the connection can be removed from the list or it is possible to edit the URL, name and other information in the panel on the right.
- Default Sources
- Web Services
- Here are the by default available WFS connections in the Geo Data Wizard visible. Also WFS connections added by a user are listed here.
- When a user added a WFS connection, the connection can be removed from the list or it is possible to edit the URL, name and other information in the panel on the right.
- Go to the 'Show Project Sources' menu
- Select the desired connection you wish to edit
- In the panel on the right, edit the name, URL, Uploader and/or description
