Queries
Clauses
The following groups of clauses exist:
Specific polygons
| Clause
As a polygon
As an item
Type
| AREA
The requested data must intersect with this area.
It must be data of this area specifically.
ID indicating a specific area.
| NEIGHBORHOOD
The requested data must intersect with this neighborhood.
It must be data of this neighborhood specifically.
ID indicating a specific neighborhood.
| ZONE
The requested data must intersect with this zone.
It must be data of this zone specifically.
ID indicating a specific zone.
| TERRAIN
The requested data must intersect with this terrain type.
It must be data of this type of terrain. There are no specific "instances" of terrain.
ID indicating a type of terrain.
Unspecific polygons
| Clause
As a polygon
As an item
Type
| AREA_WITH_ATTRIBUTE
It must intersect with at least one area with this attribute.
N/A
Attribute name of one or more areas.
| NEIGHBORHOOD_WITH_ATTRIBUTE
It must intersect with at least one neighborhood with this attribute.
N/A
Attribute name of one or more neighborhoods.
| ZONE_WITH_ATTRIBUTE
It must intersect with at least one zone with this attribute.
N/A
Attribute name of one or more zones.
| TERRAIN_WITH_ATTRIBUTE
It must intersect with terrain with this attribute.
N/A
Attribute name of one or more terrains.
Grids
| Clause
As a polygon
As an item
Type
| MAXGRIDVALUE
It must intersect with at least this value on a grid overlay.
N/A
Decimal number.
| MINGRIDVALUE
It must intersect with at most this value on a grid overlay.
N/A
Decimal number.
| GRID
It must fall within this grid.
It must be data of this grid overlay specifically.
| GRIDTYPE
It must fall within this type of grid.
It must be data of this type of grid, not a specific "instance" of this grid.
Technical name indicating a type of grid overlay.
Note that each grid automatically covers the entire map, unless a minimum gridvalue or maximum gridvalue is defined. For queries such as GRIDAVG, this can be acceptable. However, for example, a query of SELECT_LANDSIZE_WHERE_GRID_IS_2 is functionally the same as SELECT_LANDSIZE.
Also note that when a GRIDTYPE is selected but multiple overlays of that type exist in the project, there are no guarantees on which overlay is used specifically.
Constructions
| Clause
As a polygon
As an item
Type
| BUILDING
It must intersect with this construction.
It must be data of this construction specifically.
ID indicating a specific construction.
| NET_LOAD
It must intersect with the building of this net load.
It must be data of this net load specifically.
ID indicating a specific net load.
| NET_CLUSTER
It must intersect with buildings of net loads of this net cluster.
It must be data of this net cluster specifically.
ID indicating a specific net cluster.
| FUNCTION
It must intersect with constructions of this function.
It must be data related to this function type.
ID indicating a specific function.
| Clause
As a polygon
As an item
Type
| ATTRIBUTE_MAX
It must intersect with at least this value of an attribute.
N/A
Decimal number.
| ATTRIBUTE_MIN
It must intersect with at most this value of an attribute.
N/A
Decimal number.
| ATTRIBUTE
The attribute of which to test the value.
N/A
Attribute name of any polygonal item.
When neither a maximum or minimum value is specified, or when no attribute is specified, everything is considered
Multipliers
| Clause
As a polygon
As an item
Type
| ATTRIBUTE_MULT
Multiply the result by the (spatial) value of an attribute.
N/A
| FUNCTIONMULT
N/A
The name of a function value.
| CATEGORYMULT
N/A
The name of a category value.
Net line
| Clause
As a polygon
As an item
Type
| NET_LINE
N/A
It must be data of this net line specifically.
ID indicating a specific net line.
| NET_LINE_DEFINITION
N/A
It must be data of net lines of this definition.
ID indicating a line definition.
| NET_TYPE
N/A
It must be data of net lines of this type of network.
ID indicating the type of network.
Stakeholder
| Clause
As a polygon
As an item
Type
| STAKEHOLDER
The land must be owned by this specific stakeholder.
It must be data of this stakeholder specifically.
ID indicating a specific stakeholder.
| STAKEHOLDERTYPE
The land must be owned by this type of stakeholder.
N/A
Technical name indicating a type of stakeholder.
Interface
| Clause
As a polygon
As an item
Type
| INDICATOR
N/A
It must be data of this indicator specifically.
ID indicating a specific indicator.
| OVERLAY
N/A
It must be data of this overlay specifically.
ID indicating a specific overlay.
| PANEL
N/A
It must be data of this panel specifically.
ID indicating a specific panel.
Data manipulation clauses
Item
| Clause
Effect
Type
| RELATION
Rather than data of the specified item, use the item which has this relation to it.
