Machine category index (Aerius Overlay)
This functionality is deprecated and will be removed in the future.
This attribute defines the index per machine category that is used for the construction of the plan. See below for the index numbers. When multiple construction machine categories are chosen, this attribute becomes an array. Use the machine fuel usage attribute to define the fuel usage per machine category.
Construction machine categories
The below construction machine categories are the same categories that are available in the Aerius Calculator (version 2020).
Index in array Code Description Max AdBlue
0 SI56DSN Stage-I, <= 2001, <= 56 kW, diesel, SCR: nee 0
1 SI5675DSN Stage-I, <= 2001, 56-75 kW, diesel, SCR: nee 0
2 SI75560DSN Stage-I, <= 2001, 75-560 kW, diesel, SCR: nee 0
3 SI560DSN Stage-I, <= 2001, >= 560 kW, diesel, SCR: nee 0
4 SII56DSN Stage-II, 2002-2005, <= 56 kW, diesel, SCR: nee 0
5 SII5675DSN Stage-II, 2002-2005, 56-75 kW, diesel, SCR: nee 0
6 SII75560DSN Stage-II, 2002-2005, 75-560 kW, diesel, SCR: nee 0
7 SII560DSN Stage-II, 2002-2005, >= 560 kW, diesel, SCR: nee 0
8 SIIIA56DSN Stage-IIIA, 2006-2010, <= 56 kW, diesel, SCR: nee 0
9 SIIIA5675DSN Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee 0
10 SIIIA75560DSN Stage-IIIA, 2006-2010, 75-560 kW, diesel, SCR: nee 0
11 SIIIA560DSN Stage-IIIA, 2006-2010, >= 560 kW, diesel, SCR: nee 0
12 SIIIB56DSN Stage-IIIB, 2011-2013, <= 56 kW, diesel, SCR: nee 0
13 SIIIB5675DSN Stage-IIIB, 2011-2013, 56-75 kW, diesel, SCR: nee 0
14 SIIIB75560DSN Stage-IIIB, 2011-2013, 75-560 kW, diesel, SCR: nee 0
15 SIIIB75560DSJ Stage-IIIB, 2011-2013, 75-560 kW, diesel, SCR: ja 0.04
16 SIIIB560DSN Stage-IIIB, 2011-2013, >= 560 kW, diesel, SCR: nee 0
17 SIV56DSN Stage-IV, 2014-2018, <= 56 kW, diesel, SCR: nee 0
18 SIV5675DSJ Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja 0.07
19 SIV75560DSJ Stage-IV, 2014-2018, 75-560 kW, diesel, SCR: ja 0.07
20 SIV560DSN Stage-IV, 2014-2018, >= 560 kW, diesel, SCR: nee 0
21 SV56DSN Stage-V, >= 2019 , <= 56 kW, diesel, SCR: nee 0
22 SV5675DSJ Stage-V, >= 2019 , 56-75 kW, diesel, SCR: ja 0.07
23 SV75560DSJ Stage-V, >= 2019 , 75-560 kW, diesel, SCR: ja 0.07
24 SV560DSN Stage-V, >= 2019 , >= 560 kW, diesel, SCR: nee 0
25 SV560DSJ Stage-V, >= 2019 , >= 560 kW, diesel, SCR: ja 0.04
26 B2T alle werktuigen op benzine, 2takt 0
27 B4T alle werktuigen op benzine, 4takt 0
28 LPG alle werktuigen op LPG 0
29 MUT Middelzware utiliteitsvoertuigen (tot 6L cilinderinhoud) op diesel 0
30 ZUT Zware utiliteitsvoertuigen (meer dan 6L cilinderinhoud) op diesel 0
Example
We have the following fuel usages for the construction of building b:
  • 40 l / year for category: Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja
  • 10 l / year for category: Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee
First we have to map the categories to an index. According to the machine category table:
  • Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja has index 18
  • Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee has index 9
The attribute for the MACHINE_CONSTRUCTION_CATEGORY key for building b should then be set to: [18,9]
The attribute for the MACHINE_FUEL_USAGE key for building b should then be set to: [40,10]
  • Machine fuel usage (Aerius Overlay)
  • The Demo Aerius Project to see an example of an Excel Panel for choosing the machine category and filling in the fuel usage.
