How to use the Query Tool
Editor → Current Situation (Ribbon tab) → Queries (Ribbon bar)
The Query Tool can be found in the Tygron Platform Editor, under the ribbon header, in the Tools tab, by selecting the Query Tool Button. The Query Tool consists of three areas; the selection type drop down menus, the clause type and the clause value. Multiple clauses can be added using the available selection and clause options.
How to use the Query Tool:
  1. Select Editor → Tools → Query Tool
  2. Select the desired Result Parameter
  3. Add clauses, as many as needed
  4. Select the clause properties from the drop down menus
  5. Notice the full query string appears in the Query field
  6. Notice the actual Query result on the bottom of the panel
API Endpoints
