How to make an Indicator visible to only one stakeholder
To make an indicator visible to only one stakeholder, set it as "personal" for that specific stakeholder.
How to make an Indicator visible to only one stakeholder:
  1. Click on Current Situation in the ribbon bar, and subsequently click on the Indicators button.
  2. In the left panel, select the indicator that you want to adjust.
  3. With the indicator selected, locate the checkbox named "Personal (linked to Stakeholder) in the detail panel on the right.
  4. To make it visible to only a particular stakeholder, select this checkbox. A stakeholder selection box will appear.
  5. In the stakeholder selection box, select the stakeholder for which this indicator should be visible.
API Endpoints
