How to import a CityGML or CityJSON file
How to import a CityGML or CityJSON file:
- Open the Geo Data Wizard
- Select either Buildings or Measures as the type.
- Select the CityGML/CityJSON file option as the import method.
- In the next step, either choose the height defined in the model (datum height) or place the models on top of the terrain.
- After selecting the file, continue to step 4
- In step 4, choose one of these options: create a new building (assigning a function later), replace an existing building's model (creating one if missing), or only update the geometry and visualization of an existing building while keeping its attributes. If you chose the last option, you can finish the wizard.
- If you have chosen to create a new building, choose a name, function and stakeholders and then finish the wizard.
- Depending on the type you have selected at the start of the Geo data wizard, the building is directly placed in the Tygron Platform project or a new Measure is created.
- When the CityGML/CityJSON model contains no textures, the 3D model will be plain white
- Currently the modules Building (and class BuildingPart), Bridge (and class BridgePart), and CityObjectGroup of the CityGML standard are supported.
