How to change upgrade type properties
Editor → Future Design (Ribbon tab) → Upgrade Types (Ribbon bar) → The Upgrade Type to edit (Left panel)
Only user-defined Upgrade Types can be edited. To modify a default type, duplicate it first to create an editable user-defined version.
Name
- The name of the upgrade. This is the name which will appear in a stakeholder's list of actions. Depending on the effects of the upgrade, it is important to provide a descriptive name. You can change this by altering the text in the text field.
- The image seen when the upgrade is selected in a stakeholder's list of actions. A fitting image will help users identify the upgrade at a glance. You can change this by clicking the image, and selecting a new image in the opened window.
Description
- The description of the upgrade. This will also appear in a stakeholder's list of actions when the upgrade is selected. In addition to the name, a good description can be necessary to convey the intent and effect of the upgrade. You can change this by altering the text in the text area.
Cost
- The cost of the upgrade, per surface unit. You can change the cost by altering the number in the text field.
Calculation type
- The calculation type determines if cost is based on the building's ground footprint (e.g., green roofs) or total floor space (e.g., renovations). You can change this by selecting a different setting using the dropdown menu.
Construction time
- The time it takes to apply the upgrade. Regardless of the existing function of the building, or the function it is upgraded to, applying an upgrade will take the amount of time defined by the upgrade. You can change this by altering the number in the text field.
Must own
- Determines if the stakeholder must own the building to upgrade it. Otherwise, they may upgrade other stakeholders' buildings provided they have permission and pay the cost. To change this, check or uncheck the checkbox.
Zoning permit required
- Determines if a zoning permit is required for municipal approval. If disabled, no permission is needed unless the municipality owns the building and 'must own' is active. To change this, check or uncheck the checkbox.
API Endpoints
- Api session event editor upgradetype set image
- Api session event editor upgradetype set name
- Api session event editor upgradetype set description
- Api session event editor upgradetype set cost m2
- Api session event editor upgradetype set must own
- Api session event editor upgradetype set zone permit required
