How to add or remove or duplicate a Stakeholder
Adding stakeholders
In the editor, new stakeholders can be added to your project in two ways: using the ribbon bar dropdown menu, or using the left panel
Adding stakeholders using the ribbon bar dropdown menu
How to add a new stakeholder using the ribbon bar dropdown menu:
- Select "Multi Scenario" in the ribbon header.
- Select "Stakeholders" in the ribbon bar.
- Select "Add..." from the dropdown menu.
Adding stakeholders using the left panel
How to add a new stakeholder using the left panel:
- Select "Add" from the bottom of the left panel
- An "Inhabitants" Stakeholder is added to the list.
Removing and Duplicating stakeholders using the left panel
How to duplicate a stakeholder using the left panel:
- Select an existing stakeholder in your project in the left panel
- Select "Duplicate" from the bottom of the left panel
- The selected stakeholder is duplicated and added to the list.
How to remove a stakeholder using the left panel:
- Select "Remove" from the bottom of the left panel
- The selected stakeholder is removed from your project.
The left panel allows you to select stakeholders
The buttons on the bottom of the left panel enable you to add, remove and duplicate stakeholders
