Api session event editor weather set trigger sec
API Endpoint: api/session/event/editorweather/set_trigger_sec/
Description: Set the Trigger Time for the specified Weather's visualization
| 0 | REQUIRED | (WEATHER Integer ID) | Weather | |
| 1 | REQUIRED | (Floating point number) | Auto-Trigger time in seconds |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 47 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 93 ]'JavaScript example POST
body: '[ 1, 47 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/", options)
