Api session event editor weather set effect
API Endpoint: api/session/event/editorweather/set_effect/
Description: Set the Weather Type Effect of a Weather
0 REQUIRED (WEATHER Integer ID) Weather
1 REQUIRED (Enumeration) Weather Type Effect DROUGHT, FLOODING, NO_EFFECT, RAIN, SNOW or WIND
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorweather/set_effect/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "NO_EFFECT" ]'
JavaScript example POST
 body: '[ 1, "NO_EFFECT" ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_effect/", options)
