Api session event editor weather add
API Endpoint: api/session/event/editorweather/add/
Description: Add a new Weather with a Weather Type Effect
0 REQUIRED (Enumeration) Weather Type Effect DROUGHT, FLOODING, NO_EFFECT, RAIN, SNOW or WIND
200 Integer (Weather ID)
curl 'https://engine.tygron.com/api/session/event/editorweather/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"NO_EFFECT"'
JavaScript example POST
 body: '"NO_EFFECT"'
fetch("https://engine.tygron.com/api/session/event/editorweather/add/", options)
