Api session event editor terraintype add
API Endpoint: api/session/event/editorterraintype/add/
Description: Add a new Surface or Underground Terrain Type
| 0 | REQUIRED | (Enumeration) | Layer (Surface or Underground) | BRIDGE, SURFACE or UNDERGROUND |
| 200 | Integer (Terrain Type ID) |
curl 'https://engine.tygron.com/api/session/event/editorterraintype/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"BRIDGE"'JavaScript example POST
body: '"BRIDGE"'
fetch("https://engine.tygron.com/api/session/event/editorterraintype/add/", options)
