Api session event editor skill set description
API Endpoint: api/session/event/editorskill/set_description/
Description: Set the description of a Skill
0 REQUIRED (SKILL Integer ID or multiple integer values in array [1, 2, 3]) Skills
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Descriptions
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorskill/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Description 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorskill/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Description 1", "Description 2", "Description 3" ] ]'
JavaScript example POST
 body: '[ 1, "Description 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorskill/set_description/", options)
