Api session event editor global set start value
API Endpoint: api/session/event/editorglobal/set_start_value/
Description: Set the initial values of a Global
0 REQUIRED (GLOBAL Integer ID or multiple integer values in array [1, 2, 3]) Globals
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Array of values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_start_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1.0, 2.0 ] ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_start_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'
JavaScript example POST
 body: '[ 1, [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_start_value/", options)
