Api session event editor global set query timing
API Endpoint: api/session/event/editorglobal/set_query_timing/
Description: Set the calculation Timing of a TQL Query Global
0 REQUIRED (GLOBAL Integer ID or multiple integer values in array [1, 2, 3]) Globals
1 REQUIRED (Timing or multiple values in array [a, b, c]) Timings
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BEFORE" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "BEFORE", "AFTER", "AFTER" ] ]'
JavaScript example POST
 body: '[ 1, "BEFORE" ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/", options)
