Api session event editor global set book value
API Endpoint: api/session/event/editorglobal/set_book_value/
Description: Assign the Global as a Book Value for a Stakeholder
0 REQUIRED (GLOBAL Integer ID) Global
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_book_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_book_value/", options)
