Api session event editor excelsheet export
API Endpoint: api/session/event/editorexcelsheet/export/
Description: Export an Excel Sheet to Byte array content
0 REQUIRED (EXCEL_SHEET Integer ID) Excel Sheet
200 byte[] (Byte array content)
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/export/", options)
