Api event io start
API Endpoint: api/event/io/start/
Description: Start a new Session
0 REQUIRED (Enumeration) SessionType: SINGLE, MULTI, EDITOR EDITOR, MULTI or SINGLE
1 REQUIRED (String) Project Name
2 OPTIONAL (Enumeration) Language: NL, EN (optional)
3 OPTIONAL (Integer number) Preferred Session ID (optional)
4 OPTIONAL (String) Group token (optional)
200 Integer (Session ID)
curl 'https://engine.tygron.com/api/event/io/start/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "EDITOR", "Project Name" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "EDITOR", "Project Name" ]'
fetch("https://engine.tygron.com/api/event/io/start/", options)
